Configures a recovery option for instances where a software exception occurs in ExtremeXOS.
all | Configures ExtremeXOS to log an error into the syslog and reboot the system after any software task exception occurs. |
none |
Configures the recovery level to none. No action is taken when a
software task exception occurs; there is no system reboot, which
can cause unexpected switch behavior.
Note: Use this parameter
only under the guidance of Extreme Networks Technical
Support personnel.
The default setting is all.
all—The system will send error messages to the Syslog and reboot if any software task exception occurs.
Use the none parameter only under the guidance of Extreme Networks Technical Support personnel.
The default setting and behavior is all. Extreme Networks strongly recommends using the default setting.
To display the software recovery setting on the switch, use the following command:
# show switch
This command displays general switch information, including the software recovery level. The following truncated output from an ExtremeSwitching switch displays the software recovery setting (displayed as Recovery Mode):
SysName: TechPubs Lab SysLocation: SysContact: support@extremenetworks.com, +1 888 257 3000 System MAC: 00:04:96:20:B4:13 SysHealth check: Enabled (Normal) Recovery Mode: All System Watchdog: Enabled
All platforms display the software recovery setting as Recovery Mode.
The following command configures a switch to not take an action when any software task exception occurs:
# configure sys-recovery-level none
This command was first available in ExtremeXOS 11.0.
